Hi all,
What a cool site! I dabble with electronics and dabble is the correct word. I'm somewhat surprised I haven't killed myself yet. This looks like an outstanding place to learn!
I have an old car and a couple of devices on it require a bit more than 12v. I saw many step-down solutions on the net using the LM317T.
I need to step-up from 11 to 13 volts. Are there any simple circuits and off-the-shelf components that would allow for the economical (in terms on size and cost)?
The exact item I'm working on is a windshield washer pump that will not work at 11 volts (which is what I'm getting at the 2 factory leads). This is because of resistance in the power supply (harness, fuse boxes, switches). Getting the battery voltage (13) would require me ripping out and replacing about a mile of harness and I'd rather not do that. If I can step from 11 to 13 or so, It would work perfectly. I verified this on a bench.
Thanks guys! I look forward to leaning a lot here and will try not to be a pest.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
