Ballooning power generation
cjkogan111
Hello,
My purpose in writing this post is that I am looking for ideas to help with the design of a project that I am interested in working on. Rather than ask a specific question then, I will just overview the problem, and describe what I am considering for a solution.
I work with a research group that flies high altitude balloons. The longer the flight, the more batteries need to be included to power the system during flight. Thus, I was somewhat interested in looking at energy sources other than batteries. One major possibility is solar power. While this type seems more promising, I have decided to look into another source - namely extracting energy from balloon/payload oscillations.
The balloon/payload oscillations provide motion on a single axis that can be transferred to rotational motion by pushing a wheel against the main line. This can be turned into electricity by driving a DC motor with the oscillations (I'm pretty sure the output will be less than 200mA at 5V - however, who knows, it could be less than 1mA.) The output will be AC, because the motor will be turning back and forth. Thus, I will need a AC/DC power board to convert the voltage to DC. Then I can just store the charge in a capacitor to account for the changes in the magnitude of the oscillations - so that a constant current can be drawn.
Some problems I see:
I don't know how efficient DC motors are, or if there is a better way.
I don't know how heavy a AC/DC power board will be
I'm not sure how changes in the magnitude of the oscillations will effect the system
Any suggestions?
Thanks!
-cjkogan111
If your motor generation is anything near 200mA at 5V in reality, then the electronics can be very small and light - no worries there.
What kind of power levels are you trying to recover? If it is small like 1W etc.. its probably not worth the added weight for such a negligible result.
Have you looked into fuel cells? I thought they had a promise of being lighter while maintaining a higher energy density over standard batteries.
Big solar panels will be heavy and energy conversion efficiency stinks.
just some thoughts.
