Dragu Stelian
Hello!
I have a program to blink an LED, but LED does not blink and I get some messages.
#include <stadio.h>
#include <stdlib.h>
#include <xc.h>
#include "Project1.h"
void main(void)
TRISBbits.RB0 = 0; // Set PortB it 0 as Output
OSCCON = 0x72;
while (1)
LATBbits.LATB0 = ~LATBbits.LATB0;
// Create a 1 second delay loop;
for (int countDelay = 0; countDelay<20; countDelay++)
__delay_ms(50);
and hedaer file
// setting the configuration bits
#include <xc.h> // include processor files - each processor file is guarded.
// PIC18F2220 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1H
#pragma config OSC = INTIO2 // Oscillator Selection bits (Internal RC oscillator, port function on RA6 and port function on RA7)
#pragma config FSCM = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Switchover bit (Internal/External Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer enable bit (PWRT disabled)
#pragma config BOR = OFF // Brown-out Reset enable bit (Brown-out Reset disabled)
#pragma config BORV = 20 // Brown-out Reset Voltage bits (VBOR set to 2.0V)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBAD = ANA // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config MCLRE = OFF // MCLR Pin Enable bit (MCLR disabled; RE3 input is enabled in 40-pin devices only (PIC18F4X20))
// CONFIG4L
#pragma config STVR = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000200-0007FFh) not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (000800-000FFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0001FFh) is not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000200-0007FFh) not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (000800-000FFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0001FFh) is not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000200-0007FFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (000800-000FFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0001FFh) is not protected from table reads executed in other blocks)
#define _XTAL_FREQ 8000000
The message:
Clocking 4000000 specified in schematic component is ignored for oscilator mode 'INT-RC.NO CLK0'
The SCSx bits have been set.This feature is not modelled.
Do you have any suggestions ?
#include <stdlib.h>
#include <xc.h>
void main(void)
OSCCON = 0x72;
while (1)
__delay_ms(50);
and hedaer file
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
The message:
