Futterama
Hello,
I'm working on a project where I need to send 1Mbit of data from one PIC to another from one PCB to another PCB with a wire connection between them. I need the transfer to be fairly quickly (10sec). The data is read from a SPI Bus Serial EEPROM (24AA1024) and sent to the other PIC for transferring the data through USB to a PC.
The environment is noisy I guess (sending PIC is a few inches from a gasoline engine).
The wire between the PICs is one feet long, but I guess it could be shorter if needed.
So which type of transfer would you recommend? SPI, I2C, RS-232 with/without the drivers, microwire ect?
The receiving PIC is a PIC18F2550 so I would like if I could use some of its built-in communication hardware and then just select the transmitting PIC from my communications choice.
Thanks.
Regards,
Futterama
Thanks.
Regards,
Futterama
