I have a vision, I just need some help in getting there. My experience is focused more on the 12V wiring end of things, but I am able to understand conceptual and assembly of elementary electronics.
What I want to do is have a 12V input into a device that outputs a constant +12V signal for the duration of the cycle. The second output is to have a 'delayed ON' of 1 sec. The 3rd output is to have a 'delayed ON' of 2 seconds. All three outputs would remain on for 1 second and then the cycle would start over.
Why? Well I want to use add a trick tailight to the underside of my supermoto. The idea is to mount 3 flexible LED tail light strips much like these stacked ontop of one another:
Then when the brake is applied the strips of LEDs will cycle in a basic pattern. The motorcycles max output voltage to the timer would be 15V. The timer must output this voltage as the LED strips have built-in resistors to drop the voltage. I do not know the current demands of the switched side, but since its LED, I don't think it will be high but perhaps a transistor or relay may be needed.
Where do I start?
Where do I start?
