Boiler control application. PWM output with a PIC16F876 to control valve.
I have downloaded both the compiler and HI-TECH PICC LITE v9.50 PL2, I then select the HI-TECH PICC Toolsuite. But when a build the code i get the following error:
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Users\Mitchell\Desktop\PWM\pwm main.cce".
Clean: Done.
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC-Lite\9.50\BIN\PICL.EXE" -C -E"pwm main.cce" "pwm main.c" -O"pwm main.obj" -Zg9 -O -ASMLIST -Q -MPLAB -16F876
Error[922]   : chip "16F876" not present in chipinfo file "C:\Program Files (x86)\HI-TECH Software\PICC-Lite\9.50\dat\picc-lite.ini"
Halting build on first failure as requested.
BUILD FAILED: Fri Aug 17 09:56:24 2012
any ideas?
Try sticking this in the picc-lite.ini
[16F876A]
MAKE=MICROCHIP
ARCH=PIC14
PROCID=876A
FLASH_READ=1
FLASH_WRITE=8
FLASH_ERASE=8
FLASHTYPE=READWRITE_A
IDLOC=2000-2003
CONFIG=2007-2007
EEPROMSIZE=100
ROMSIZE=2000
BANKS=4
RAMBANK=20-7F,A0-EF,110-16F,190-1EF
COMMON=70-7F
DATABANK=2
ICD2RAM=70-70,1E5-1F0
ICD2ROM=1F00-1FFF
ICD3RAM=70-70,1E5-1F0
ICD3ROM=1F00-1FFF
Other than that you need to download the PRO version and run it in lite mode ( this is what happens when you use the MPLAB install)
haiiii Ian,
Error[922] : chip "16F913" not present in chipinfo file "C:\Program Files (x86)\HI-TECH Software\PICC-Lite\9.50\dat\picc-lite.ini"
please help me....
[MODNOTE]Deleted Off Topic[/MODNOTE]
