futz
Active Member
What you're looking for is called a C compiler.how to get C code (never used this type before) to assembly to hex? (think thats right)
So what kind of compilers would you suggest other than BoostC, HATE that program never works for me!
I always recommend BoostC. My favorite PIC compiler. It's real easy to use. Be sure to integrate it into MPLAB and use MPLAB rather than the BoostC IDE. Easier that way, IMHO.So what kind of compilers would you suggest other than BoostC, HATE that program never works for me!
Did you remember to put #include <system.h> as the first line of your program?Its probably a simple fix, but i am kinda new to it
Thank you.Ohh and NICE website!
Hahahaha! I didn't think of that. That would definitely do it.You have selected a 8 pin chip and so it doesn't have portb. Try changing the chip to something like a 16F88.
:020000040000FA
:0400000004EF00F019
:040008000300FED71C
:020000040030CA
:03000100220E0EBE
:02000500018177
:060008000FC00FE00F40E5
:00000001FF
Maybe. Depends what you're doing. Test it and see.It said it was a success but the HEX is tiny
is it supposed to be that small?Code::020000040000FA :0400000004EF00F019 :040008000300FED71C :020000040030CA :03000100220E0EBE :02000500018177 :060008000FC00FE00F40E5 :00000001FF
You just did? There's a thing called Add To Reputation at lower left of all posts, if that's what you mean.P.S. Can you give thanks on this forum?
You'll have to post your source code. Use Code tags by clicking on the # icon just before pasting.YA, its a NO GO, can someone, please convert it to hex for me PLEASE?
* Project: 12F683 Test v1 *
* Source: 12F683_Test_v1.c *
* Author: Mike McLaren, K8LH *
* Date: 19-Jun-08 *
* Revised: 25-Jun-08 *
* Charlieplexed 20 LED Demo with 32 PWM levels per LED *
* IDE: MPLAB 8.01 (tabs = 4) *
* Lang: SourceBoost BoostC v6.87, Lite/Free version *
#include <system.h>
#pragma DATA _CONFIG, _FCMEN_OFF&_IESO_OFF&_MCLRE_OFF&_WDT_OFF&_INTOSCIO
#pragma CLOCK_FREQ 8000000 //
//--< function prototypes >------------------------------------------
//--< type definitions >---------------------------------------------
//--< variables >----------------------------------------------------
unsigned char led[20]; // led matrix, pwm values 0..31
unsigned char shadow = 0; // isr, trisio shadow register
unsigned char colpos = 1; // isr, gpio column ring counter bit
unsigned char dcy = 15; // isr, duty cycle counter, 0..31
unsigned char dc0 = 0; // isr, row 0 (gp0) pwm value, 0..31
unsigned char dc1 = 0; // isr, row 1 (gp1) pwm value, 0..31
unsigned char dc2 = 0; // isr, row 2 (gp2) pwm value, 0..31
unsigned char dc3 = 0; // isr, row 3 (gp4) pwm value, 0..31
unsigned char addr = (unsigned char) &led;
//--< defines >------------------------------------------------------
#define end_of_period dcy.5 // isr, end of 32 pwm steps
#define end_of_cycle colpos.6 // isr, end of 5 column update cycle
//--< main >---------------------------------------------------------
void main()
osccon = 0b01110000; // set 8 MHz INTOSC
while(!osccon.HTS); // wait 'til oscillator stable
cmcon0 = 7; // comparator off, digital I/O
ansel = 0; // a2d module off, digital I/O
trisio = 0b00111111; // set all pins to inputs
gpio = 0; // set all output latches to '0'
// setup 100 usec Timer 2 interrupts (8 MHz clock)
pir1 = 0; // clear peripheral interrupt flags
pie1 = 0; // clear peripheral interrupt enables
pie1.TMR2IE = 1; // set Timer 2 interrupt enable bit
tmr2 = 0; // clear Timer 2 register
t2con = 0b00000100; // '0-------' unimplemented bit
// '-0000---' TOUTPS<3:0>, postscale 1
// '-----1--' TMR2ON, turn Timer 2 on
// '------00' T2CKPS<1:0>, prescale 1
pr2 = 200-1; // 200 x 500-nsec 'ticks' = 100 usecs
intcon = 0b11000000; // '1-------' GIE, enable global ints
// '-1------' PEIE, enable peripheral ints
// '--0-----' T0IE, TMR0 ints disabled
// '---0----' INTE, off
// '----0---' GPIE, IOC disabled
// '-----000' T0IF/INTF/GPIF flags
// simple led interface to pwm driver, duty cycle values of 0..31
led[0] = led[19] = 1; //
led[1] = led[18] = 1; //
led[2] = led[17] = 4; //
led[3] = led[16] = 0; //
led[4] = led[15] = 0; //
led[5] = led[14] = 1; //
led[6] = led[13] = 1; //
led[7] = led[12] = 0; //
led[8] = led[11] = 1; //
led[9] = led[10] = 1; //
while(1) //
/* interrupt service routine */
/* 100 usec Timer2 interrupts, 32 interrupts/column (3.2 msecs) */
/* for 32 pwm brightness levels. 160 interrupts (16 msecs) for a */
/* complete 5 column update cycle (62.5 Hz refresh rate). */
/* led array duty cycle parameter values of 0..31 produce actual */
/* duty cycles of 0% to 20% per LED in 0.625% (100 usec) steps. */
/* 57 to 84 cycles or approximately 42% "overhead" (8 MHz clock) */
void interrupt()
if(dc0 == dcy) // if row 0 duty cycle match
shadow.0 = 0; // clear shadow bit (gp0)
if(dc1 == dcy) // if row 1 duty cycle match
shadow.1 = 0; // clear shadow bit (gp1)
if(dc2 == dcy) // if row 2 duty cycle match
shadow.2 = 0; // clear shadow bit (gp2)
if(dc3 == dcy) // if row 3 duty cycle match
shadow.4 = 0; // clear shadow bit (gp4)
dcy++; // increment duty cycle counter
asm
{ movf _colpos,W //
andwf _shadow,W // is the float bit required?
btfss _status,Z // no, skip, else
iorlw 0b00100000 // set the 'float' bit
iorwf _shadow,W // pick up led bits
iorwf _colpos,W // pick up column bit
xorlw 0b00111111 // invert all
movwf _trisio // update the column LEDs
if(end_of_period) // if all 32 pwm steps complete
{ dcy = 0; // reset duty cycle counter
asm
{ bcf _status,C // shift column bit mask
rlf _colpos,F //
btfsc _colpos,3 // if gp3 bit position
rlf _colpos,F // shift to gp4 bit position
if(end_of_cycle) // if all 5 columns have been updated
{ colpos = 1; // reset colpos bit to column 0
asm // reset led[] array address pointer
{ movlw _led //
movwf _addr // addr = (unsigned char) &led
shadow = 0b00010111; // setup shadow (all row bits "on")
gpio = colpos; // setup output latch, only 1 bit high
fsr = addr; // setup new column pwm work variables
dc0 = indf; // row 0 (gp0) pwm value, 0..31
fsr++; //
dc1 = indf; // row 1 (gp1) pwm value, 0..31
fsr++; //
dc2 = indf; // row 2 (gp2) pwm value, 0..31
fsr++; //
dc3 = indf; // row 3 (gp4) pwm value, 0..31
addr = fsr + 1; // save array address
Code:/********************************************************************
Don't be too sure. I might be a lowly worm. I didn't test it.YOUR A GOD!!! thank you!
