C++ programming
tuck
Hi all,
sorry to disturb u guys again.
i having a problem with my study.
i have no no idea how to solve the question.
can any1 help me to solve it?
thank you very much.
The reading in the page of this is hard for me to comprehend. but I'm guessing you're working with arrays.... obliviously.
Just out of curiosity what compiler are you using? and the OS.
Arrays
That helped me a lot when I was learning arrays.
Small chuckle to myself....I'm 14 and I'm guessing this guy is in collage..... and yet I'm failing in school.
Hey tuck I've got a question for you. I'm stuck on this code right now. I'm trying not to look in any of my books or anything. but I compiled this code with no errors and it closes when you enter a number
#include <iostream>
using namespace std;
int main ()
  int i;
  cout << "Please enter the degrees in Celcius ";
  cin >> i;
  cout << "That number in fahrenheit is: " << i*1.8 + 32 << ".\n";
  return 0;
and for some reason it's not coming out right. its going to keep me up all night that a super simple code is not working.
David,
That code works fine. See attached.
hey. not to hijack the thread but heres my code.
#include <iostream>
int main ()
  double i;
  cin >> i;
  cout << "That number in fahrenheit is: " << (i*1.8)+32 << ".\n";
  return 0;
Hi david,
I'm using CodeBlocks with the Ming G++ compiler. Are you sure it isn't just the window shutting down. Try changing your code to,
#include <iostream>
int main ()
  int i;
  while(1){
      cin >> i;
  return 0;
When you want to quit out of the above press Ctrl-C.
Oyyyyy, not all compilers are same, some follow standards, some bend them:
Try this:
#include <iostream>
int main (){
  double i;
  cout << "Please enter the degrees in Celcius: ";
  cin >> i;
  system("pause");
  return 0;
This is really really pissing me off. Every program i write and compile it closes when you enter a number in the console and hit "enter". I googled this and nothing relative to this topic is around.
I've attached the zipped exe file, what happens if you run this?
Did you download the version of Dev-C++ that included the mingw compiler?
  • temperature.zip
Yeah that one works. althought i would put the system pause before the cin and cout's. i will uninstall and reinstall devC++
