SiriusHardware
Thanks for doing that - I do believe you when you say that a much newer version works just the way you say it does (ie, painlessly). But I find it hard to believe that nobody ever got these older versions working.
What do you think the newer versions are? They're improvements on the older ones![]()
You're right of course - I'm going to have to install a newer version on one of my spare PCs, if only to see something working. But I still need these old ones to work, eventually, on that Windows 98 relic at work.
I have been using MPLAB since version 6. However! Not with C... But I'm sure I was using C18 version 3.32 on MPLAB 7.62... I never had these issues... I still think the installation went south somewhere.... Pic18f452 was supported back at version 7.62 as this was the chip I always used... ( I use 4520 now ). So I don't think it's a version fault, nor do I think the OS is to blame.. 98 was pretty stable.....
I still think its a "path" issue!
Is there any reason why you have a die hard 98SE (I'm gonna make it work ) campaign going? Will XP not work with this machine?
I must admit that I didn't / wouldn't shift from 98SE.... But XP has really proved itself....... (
I occasionally have to bale out for a couple of minutes while someone programmes a 27C128 or something.
