bobledoux said:I use laser mailing labels to stick my toner transfer sheet to a larger sheet of paper.
evandude said:I have always used clear (scotch) tape for that, and it's never been an issue.
Rolf said:My tape is leaving some sticky residue on my PnP which in not an issue unless I am saving it for later use. I forget it is there and the sheets stick to other sheets. Will try bobledoux suggestion and use laser printing labels the next time. I guess this proves that all tapes are not created equal.
Oznog said:There was a guy on eBay awhile back selling like 10 lb and up bottles of solid Ferric Chloride lumps.
Easy enough to turn that into etchant. At first I thought a pound of that stuff would make a lot of etchant. However, I did some calculations and saw that the ferric chloride is actually a very substantial part of the etchant's weight. It was still significantly less $ than buying etchant, but not a miniscule fraction of the cost.
One of the transfer sheet companies has been advocating dumping the etchant tank entirely in favor of applying the ferric chloride etchant with a sponge (while wearing gloves), literally rubbing it on. They say this etches a board far, far faster and in the end uses less etchant.
which would explain why the sponge method works so well for ferric chloride, but is not really helpful for persulfate etchants.insoluble copper(I) film formed with ferric chloride or cupric chloride as being the limiting factor on etch rate. Persulfate on the other hand do not form insoluble surface films, and so etch rate is limited only by solution kinetics
unbwogable said:Bobledeux:
I have a question about the pulsar etching system. Does it work that great? I have some of the paper, and I can't get the toner to transfer for crap! I've tried a dozen different copiers, and I've tried a clothes iron, and two differents heat laminators. Suggestions?
3v0 said:What is the substrate PCB material ?
Some are more prone to breaking then others. Fiberglass would be good.
Use a sharp bit.
Do not push, let the drill do the cutting. Small bits heat quickly. Forcing them makes it worse. Hot drills go dull quickly. May only last a few holes.
Carbide bits stay sharper longer but break easily unless you use a drill press or drill stand. You should be using a drill stand or drill press.
Use a CNC machine![]()
Rolf said:....... one of the most important things, drill speed (RPM), the higher the better.
Hero999 said:Press-n-Peel is a waste of money, I just use ordinary magazine paper.
Krumlink said:One problem I have with the HCL etchant is that if you dont mix it correctly, it washes off the ink right off the board![]()
