Now that makes me wonder if HHO worksMaybe I know some things you don't.![]()
I would be grateful if you could video your attempt and upload it, i am sure it would be of great educational value.
What an excellent suggestion.I would be grateful if you could video your attempt and upload it, i am sure it would be of great educational value.
Where you been? i do upload pics!What an excellent suggestion.
Now that you mention it, how about some pictures of some of your technological adventures and exploits?
As they like to say on a machining site which I visit from time to time...
"Pictures, or it did not happen"
Get that camera going LLG.
I don't remember that, can you show me?Last time you asked (i did upload foy you after all the agro of doing that) i asked you a question based on the pics and datasheet i uploaded (was radio micro board and micro sized antenna question), you didnt bother replying to it,
I will look for it tomorrow, it was a while back. i remember it because i was well miffed spending all that time uploading and then you didnt answer the question i posed in response to yours!!I don't remember that, can you show me?
You won't learn it all in day but in a week of spare time you will be someplace comfortable on the basic concepts and shortly after that you will have a very solid idea of what you would need to make a system work for yourself.
You showed your fuel nozzle and pre-heater earlier ... I gather the pre-heater needs to run continually ... you don't turn it off once the system is running ... and rely on the operating temperature within the heater?
Its controlled by the PID loop controller unit which keeps the nozzle around 300F. It's about 500 watts but cycles on and off in short bursts so the overall heating wattage is maybe half that.
The burner and blower is just a common fuel oil furnace burner unit which is something like 1/6 Hp and draws maybe 100 - 150 watts. It could be way smaller if that motor didn't have to drive the little pump that supplies the nozzle with oil at 120 - 150 PSI.
Problem with researching ... you come across a million different ways of doing things.![]()
Also, don't forget that some things, like with the Pex type tubing, you need a special crimping tool to put it together so either you need one you can borrow our you may be out some more money to have one of your own.
Wow those Pex tools are out of most peoples reach! Let's see now a guy is going to spend$1k or more to do the tr*vis heat system, but can't be able to afford a Pex crimper?
Look it dosnt take a genius to know that cracking oil with a naked flame is just plain stupid, so your comment about knowing things i dont is just you being you, you not liking the fact others can spot your mistakes a mile off. The fact that when gaping holes are found you would rather fight a lost point than admit someone knew better than you, i suspect it erks even more when they are my age.I don't follow the connection or implication. Are you implying that other heat sources cant heat oil and that only electricity works to heat it, or that HHO could work for heating it? Your continued lack of direction and clarity in your comments make your understandings and intent hard to follow what you are going for way too often.
As for documenting it I will likely take pictures and do a write up when I get to it someday. But for now it's on the lower end of the priorities list. As for video I don't do video and have no interest in ever starting to.
Keep in mind when you centrifuge waste oil you get the thinner fraction, i get the feeling the oil is much cleaner than TCM is using. I use a higher pressure pump than standard and a slightly bigger jet, but my preheat sounds very different to his.Thanks, that all helps.
Truth is i study this stuff at advanced level, my chemistry and labs skills have been honed in a lab almost my entire life,
Most EU based energy sites that advocate waste oil systems, all mention the horrors of carbon monoxide or other gases we cant know about.
Never forgot your burning a mix of things, it stuff that gets thrown into waste oil barrels. An example is one source i cant/wont use, the garage has a bodywork shop in it and they dump waste solvents in the waste oil barrels. It would be stupid to risk it as they tend to have a high ratio of solvent to oil. How do i know? Gas chromatograph, but in this case you dont need one, they use so much of it you can smell it in the oil.
I wont be posting alternative energy stuff here any more, the threads get swamped with nonsense.
The main thing to consider is the sitting down and putting hard numbers to the prices of the different ways you can go with the system. Just because something costs a lot does not mean it's best or that it's best for what you may need to do.
Yes and where you live its considered reasonable for any novice to make high explosives and set them off with next to zero knowledge. Direct flame cracking on a small scale is not safe, on a large scale its being phased out.Direct flame cracking is used everywhere for crude and used oil distillation/fractionation systems from the huge industrial scale down to the micro DIY level
Your only mention is having plenty of BTU's at your disposal and references to used tires etc. The fact you mention open flame cracking i would consider proves my point your thinking of open flame. Other countries read this forum, the advice your giving pertains mainly to one part of the world. Your information is extremely dangerous and while you may care, i certainly care if people think its perfectly safe to do just because you said it was.Where did I ever say I was using and open flame and doing it directly?
Again another big difference between where you live (which is almost third world in its approach to environmental issues) and the rest of us, its better to clean an oil to the point it dosnt need to be out doors to be safe or meet regs, rather than just take a lazy dont care attitude and spew toxins everywhere.Rather why they get used as outdoor or in shop or commercial type heat systems rather than in house home heating. Its why I have my boilers in low occupancy hell vented locations like my small work shed and the old shop where venting the places out is of no issue should there be a excessive smoke back problem.
Same reason I recommend going full outdoor boiler designs as well where the mess and smoke issues are of little to no real concern unless you are doing something extremely bad in highly unusual conditions.
You more than anyone should be aware i am ALWAYS able to back what i say with high quality scientific papers from quality journals, i unlike yourself do not rely on random websites with no credibility.but so far you haven't gotten the hang of it. Also, claiming anyone who disagrees with you (by their bringing verifiable facts, evidenced experience to support themself while refuting you) to be liar really doesn't help you on your credibility either.
If I was you I would start by doing my research far better and backing my claims up with actual verifiable data and even extended real world hands on experiments wasn't just a controlled lab environment to slow that problem down a bit.
there's a lot to be said for simple solutions. somebody once told me about a US contractor that came up with an expensive "cannon" that shot BBs at hundreds of thousands of feet per second. after the cold war ended the contractor went and saw a russian engineer that used a mailing tube filled with solid rocket propellant, and a block of explosives (to the tune of about $5 worth of materials) to achieve the same results.
btw, i think the US contractor's experimental setup in the story is the hypervelocity test facility run by NASA. **broken link removed**
