Hi everybody . I'm working on a couple of projects that will need analog<->digital conversion. I've been required to work using an FPGA (I have a Spartan 3 Starter board) and the AD7823 (ADC) and AD7303 (DAC) serial converters, I got this board from Digilent: Digilent Analog I/O 1. I've managed to control the ADC (after some corrections to my program), but I've been trying several times and had no success with the DAC. So I'd like to ask whether you've worked with this chip and/or if you have any advice/idea what I may be doing wrong .
This is my current code (I've been changing it a bit):
This is my simulation output (test bench waveform module in Xilinx ISE):
I'm trying this:
- sclk toggles every two rising edges of the 50 MHz clock in the Spartan board.
- sync stays high for 40ns and then changes to 0 while the data (16 bits) is sent to the AD7303.
- data bits are put on din when sclk is low, the AD7303 is supposed to read on sclk's highs.
I'm simulating the 8 bit value to convert using the eight slide switches included in the Spartan3 board, but the AD7303 output does not change when I open/close the switches. I'm powering the AD7303 with 5Vcc, and using its internal reference.
Please, any advice/comment will be of help. I'm trying to get another AD7303 to confirm mine is not damaged, since I think my program should work .
Thanks for your attention,
José Jorge Enríquez.
-- Control AD7303
-- José Jorge Enríquez Rodríguez
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity control_dac is
port(
clk_50MHz: in std_logic; -- Board clock (50 MHz)
reset: in std_logic;
data: in std_logic_vector( 7 downto 0 ); -- Data
dac_sync: out std_logic;
dac_sclk: out std_logic;
dac_din: out std_logic
end control_dac;
architecture Behavioral of control_dac is
begin
process( reset, clk_50MHz )
variable temp: integer := 0;
begin
if ( reset = '1' ) then
temp := 0;
dac_sync <= '1';
dac_sclk <= '0';
dac_din <= '0';
elsif ( rising_edge( clk_50MHz ) ) then
temp := temp + 1;
if ( temp < 3 ) then -- Starts sync high
dac_sync <= '1'; dac_sclk <= '0';
elsif ( temp < 5 ) then
dac_sync <= '1'; dac_sclk <= '1'; -- Ends sync high
elsif ( temp < 7 ) then -- Starts data transfer (bit 16)
dac_sync <= '0'; dac_sclk <= '0';
dac_din <= '0'; -- Internal reference
elsif ( temp < 9 ) then
dac_sync <= '0'; dac_sclk <= '1';
elsif ( temp < 11 ) then -- (bit 15)
dac_din <= '0'; -- Uncommited bit
elsif ( temp < 13 ) then
elsif ( temp < 15 ) then -- (bit 14)
dac_din <= '0'; -- LDAC
elsif ( temp < 17 ) then
elsif ( temp < 19 ) then -- (bit 13)
dac_din <= '1'; -- Disables channel B
elsif ( temp < 21 ) then
elsif ( temp < 23 ) then -- (bit 12)
dac_din <= '0'; -- Enables channel A
elsif ( temp < 25 ) then
elsif ( temp < 27 ) then -- (bit 11)
dac_din <= '0'; -- Address channel A
elsif ( temp < 29 ) then
elsif ( temp < 31 ) then -- (bit 10)
dac_din <= '0'; -- CR1
elsif ( temp < 33 ) then
elsif ( temp < 35 ) then -- Last config bit (bit 9)
dac_din <= '1'; -- CR0 (update DAC input reg. from shift register)
elsif ( temp < 37 ) then
elsif ( temp < 39 ) then -- MSB data (bit 8)
dac_din <= data( 7 );
elsif ( temp < 41 ) then
elsif ( temp < 43 ) then -- (bit 7)
dac_din <= data( 6 );
elsif ( temp < 45 ) then
elsif ( temp < 47 ) then -- (bit 6)
dac_din <= dato_paralelo( 5 );
elsif ( temp < 49 ) then
elsif ( temp < 51 ) then -- (bit 5)
dac_din <= data( 4 );
elsif ( temp < 53 ) then
elsif ( temp < 55 ) then -- (bit 4)
dac_din <= data( 3 );
elsif ( temp < 57 ) then
elsif ( temp < 59 ) then -- (bit 3)
dac_din <= data( 2 );
elsif ( temp < 61 ) then
elsif ( temp < 63 ) then -- (bit 2)
dac_din <= data( 1 );
elsif ( temp < 65 ) then
elsif ( temp < 67 ) then -- LSB data(bit 1)
dac_din <= data( 0 );
elsif ( temp < 68 ) then
else
temp := 0;
end if;
end if;
end process;
end Behavioral;
I'm trying this:
