That's pretty standard. Is faster to produce because less copper needs to be etched and makes less waste and more environmentally friendly because less etchant is consumed. Also, it helps keep the copper on both sides of the board even to prevent the board from warping, but this is apparently no longer an issue in modern boards.I don't know who designed the originals but just about every bit of space between tracks is filled with areas connected to ground. Absolutely nightmare when re-tinning everything as whiskers catch me out every time.
I don't get why it's tinned so heavily either. It doesn't look like there are high currents anywhere. However, the planes don't cover the entire board so it looks like they were intentionally put there for some reason.
