Warlord_1011
hello all
I am currently in the process of designing my own Amplifier.
Now here is the Issue, i need a volume control for 6 inputs (so the Amp is 5.1 Capable)
now i basically need either a chip or some sort of setup what will control 6 AC input signals, controlled by a single pot.
My idea was to use transistors and vary the base current (NPN) to vary the transistors Resistance (as part of a voltage divider) however the Negative part of the signal was not effected
so to summarize all i need is 6 inputs to be controlled by a single DC input via a pot, what then effects the output of the "Black Box"
any questions please ask me if i have not made myself fully crystal clear.
thanks in advance
thanks in advance
