weekendguy
spec You are too good to me. Many Many thanks. Please excuse the dumb question but the 0-10vdc output is with respect to the 0v line? Also, I will need to have the output flatten out at some point and be scaled. It may turn out that the 0-10vdc range only needs to reflect a 30C range where anything above 30C it pins at 10v and any diff <= 0C outputs something higher than 0, perhaps 4. I probably did not do a thorough job explaining this in my first post.
Is there a place in this circuit where I can adjust "range" and "floor" by changing components?
If this is becoming too complicated I could revisit the Arduino approach. I would then just need a way to get the 0-5v output shifted up to 5-10v. I guess that may only need a voltage divider...?
