I’m trying to use a digital potentiometer to replace a mechanical pot. The digital pot is the Rensas X9511. (X9511 datasheet attached) I have it wired for autostore as shown in figure 2 on the datasheet.
The problem is that the autostore function is not working. Connecting an ohmmeter across pins 3 and 5 (resister element terminals) show changes in resistance with use of the up/down push buttons but the resistance is zero if the power is disconnected (switched off) and then back on. Any ideas?
The first question is it acceptable to use the same power source for both the chip’s control circuitry and for the resistor elements leads? In other words, is acceptable to parallel the circuits Vcc and Vdd with the high and low leads of the resistor element?
Can someone explain the purpose of the Schottky diode on the Vcc lead? The datasheet doesn't show one as needed for the manual (push bottom) store.
Any and all help will be greatly appreciated.
