Hi. I'm new here so please forgive my unfamiliarity with the nuances of this site. (Any guidance is appreciated!) I'm looking to design an electronic keypad wall-safe with some additional "non-standard", but relatively simple, features not typically available in current products. I am in management and marketing and although I aced calculus 20 years ago, have no engineering experience/education, so this is way beyond my ability. Depending on the time/cost I would possibly like to hire someone to design the circuit board for me.
To give you a good idea of what the project entails here a few (but not all) of the features I am looking incorporate...
One of the features I would like to modify from standard is to make it hard wired to AC, with a battery back-up that uses standard AA(?) NiMH rechargeable batteries. The AC needs to power the safe and (smart) charge the batteries.
An LED light on the front of the safe needs to alert the user to depreciated battery capacity (similar to PC UPS battery back-ups), whether it is currently being powered by AC or the batteries. If this is too difficult or costly then a "battery-low" light would suffice.
It needs LEDs to light the safe interior while the door is open, with a small switch inside the door to disable the lights if the owner so desires.
Because the owner of the safe may not be able (or want) to hard wire, the batteries should be able to power the safe for 12 months while being accessed 2x every day (with interior lights disabled). This is similar to the battery life on existing safes.
I would also like to incorporate door contact sensor so that the owner can connect the safe to a home security system. I know this alone would have nothing to do with the control board, but could it be dual-purpose, and control the interior lights (using the same power supply as the board) as well?
Lighted keypad. (illuminates on first press)
Confirmation LED on front of door near keypad that comes on while a key is pressed, and lights solid for approx 5 seconds upon user entering a valid access code and the safe unlock handle being released by the electro-magnetic bolt.
LED that blinks, notifying owner of invalid access code attempt. Notification clears upon next valid access.
Then, of course, the standard stuff to be expected, such as the user being able to change the access code or reset to default (by holding a reset button located inside the safe for a predetermined length of time), timed lock-out function for invalid access attempts, etc. (specific access code programming procedures, lockout duration, etc. can be discussed when the time comes to actually begin the design process)
Additional note: the safe will have a physical key override (in case of both power sources failing or there is a need to reset a forgotten access code) and it's almost unnecessary to state, but it has to be super reliable.
I don't know if there are existing boards and parts that could be used/modified/pieced together, or if it would be better to design from the ground up. Due to the nature of the project there will be physical space limitations, so the smaller the better. I've also wondered about the hard wiring aspect as far as whether or not an AC adapter of some type would have to be used or if there is an "on-board" solution, as well as if there are any safety issues with putting an AC adapter inside a wall or enclosed safe.
I have heard that having a PCB of low to low-medium complexity can range from $500 to $1500. Is this fairly accurate? How do I find someone reliable?
Any advice on where to begin would be great!
