Egg Incubator repair help
tonywolfin
Hello, first time post here and not much electronics knowledge, but a willing spirit! I am trying to repair my failed RCOM PX20 Digital egg incubator. It's quite an old model however I do like how it works.
I was using it until couple of day ago, it was on and working properly, then i unplugged it to move it and when I plugged it back, it did a small noise and won't start anymore.
I did the following tests with a multimeter :
1- I tested the input when plugged at the CN1 and CN2 connections and it has 236V (France)
2- I did a continuity beep test on the transparent fuse, it beeps.
3- I tested what I think is the transformer in yellow. It seems to have 2 legs on one side and 4 on the other. The 2 on one side seems to beep when unplugged.
4- I tested the bridge rectifier KBP206S, it has a + AC - writing on it. Unplguged, I tried every combination with the conitnuiy test, but no beeps at all in any direction. I plugged it and tried to get the + and - tested together with my multimeter DC mode 20v and 200V but both come up with -1 on the screen.
That's how far i am (with ChatGPT), are you able to support and help me test and see what could be wrong so I can replace it ? No electronics store nearby and shipping is expensive, so I would rather order everything in one go rather than multiple times if possible. Thanks for your help and hope I can fix this :)
Tony
Can you get a photo of the back of the board?
If your only bit of test equipment is a multimeter that can only read up to 200 V on DC, fault finding this is going to be very difficult.
I would expect about 350 V DC between + and - on the rectifier when it is working, which probably shows up as "-1" to indicate an overload on a cheap multimeter.
Can you measure the voltages between the pins at the bottom of the photo?
That is a power supply and the device labelled TH1 is a triac that turns on and off the heater. I am not sure what controls the triac. Can you show what else there is in the incubator, that the connections at the bottom of the photo go to?
Thanks for the quick reply. I uploaded a picture of the multimeter I'm using, Your guess is right, its likely a cheap model I had for years. I am considering buying a new, any tips would be welcome. I also posted a picture of the bottom of the board. The components of the machine are the following : 2 fans (red and black wires) one turning motor (yellow and black wires) then the rainbow/grew cable goes to the digital display in the front. It also connects to a small PCB board that I think has a humidity detector and thermometer next to the digital display. I think there is also a heating element upfront that goes into the water, you can see some chalk traces on it. it also has a fan next to it.
I measure with Setting 20V DC the 3 legs of the TH1 component, I get a fluctuating reading of 0.00 to 0.06 max with the - appearing every now and then. Hope this helps
One more thing, the rectifier has 109 on leg 1 and 2 and also 109v on legs 3 and 4. while it has 339V on 1 and 4 and nothing on 2 and 3. Not sure how to interpret that. Thanks
Perfectly correct - you're measuring from the negative leg of the bridge, so the negative leg will read zero - when you measure the positive leg, then it reads full rectified mains (350V odd), the other two legs are the AC input and will read roughly half of the positive pin. Anything wrong in that part of the circuit, and the voltages on the bridge would be catastrophically wrong, there's also no point measure on the AC inputs, or on the negative pin, you only need to measure from negative to positive.
The fault is unlikely to be there anyway, it's FAR more likely to be in the switch-mode circuitry - but that's not really a place for beginners to be messing.
thanks for the reply. I am not ready to give up on it to be honest. I think it's quite an expensive piece of equipment and I would like to try and fix it with your support. Would you be willing to support in helping me go further? thanks
Can you measure all the voltages on the pins on the white connectors and on the multicoloured cables? It might not be the power supply, but those measurements would show it one way or the other.
First Disconnect the 240V from the Incubtor and wait about half an Hour ( so the Capacitators can discharge ).
240V are definatly deadly!
I think You have a Problem with the switching Power Supply.
That can be caused by an Overload on primary or secundary Circuit.
Sometimes the Diodes on the secundary side go fail.
Then there is an Overload and the Power supply shut off.
Your Multimeter has an Diode Test!
Use this to measure all the Diodes in the Circuit.
In forward Direction there must been measured about 0,2 up to 0,7V.
When measure lower than 0,15V the Diode is probably fail.
Backwards there should be shown overload ( Open ).
Another Part that make sometimes Problems are the Elecrolytic Capacitators in the Circuit.
Sometimes You can see it Optically ( The upper Side come a little up, or the Rubber seal on Bottem Come out ).
When there is nothing to see Measure across the Capacitator. There should not be a Short.
A higher resistance is possible by the circuit after the Capacitator.
When there is measured a short, solder out and measure cicuit and Capacitator again.
When You not have a good Soldering Equipment ( Good a Soldering-, better a Desoldering Station ) consult a Friend who has some.
That avoid damaging the PCB ( I've seen to many of them ).
Some Switching Power Supplies has a Start up Circuit at the Primary Side of the Switching Power Supply.
Most it is realized with 1 or 2 Resistors and a Capacitator. Measure the resistors in primary if the Values are OK.
Look first for this Things if there are fails. When that's all OK let's look for further solutions.
Tony
I can see a big capacitor in the second picture. Did you test that?
alphamodi.com
Tony
Since your fuse is good but the bridge rectifier (KBP206S) shows no continuity, it’s likely faulty. Test transformer output (AC voltage on secondary pins). Replace rectifier first—common failure point.
