nickelflippr
I have modified an electret mic amp from the schematic of a frequency analyzer detailed in a **broken link removed**. This is my first look at this subject, and my guess is that the circuit includes a couple of buffers, with a gain stage, and a low pass filter at the end? So entertaining comments on the attached circuit. Everything seems to be working O.K. currently. Would it be better to start over with something else?
The electret mic (WM-54B) Op-amp (MCP609) circuit feeds a 7 band equalizer chip (MSGEQ7) which is controlled by a couple of PIC outputs, and read by a single analog input. The equalizer chip has the filters set for 63, 160, 400, 1k, 2.5k, 6.25k, 16kHz. So the circuit component changes came about, right or wrong, for various reasons stated below:
1) Needed to reduce gain because the MSGEQ7 adds 20 db to final output so reduced the pot to 50kΩ.
2) Low pass filter was set around 10 kHz so changed R7 to 180Ω for around 20kHz to nab the highest bandpass filter.
3) Substituted the MCP609 for the LM324. The MCP609 is rail to rail, but a relatively low bandwidth of 155kHz. Looking at improving that with a MCP6274 which is supposedly 2Mhz.
4) The current electret doesn't make the 63Hz band , so will upgrade to WM-61A which is supposed to be from 20-20kHz.
3)Didn't have the C6 150nf cap, so substituted a 220nf one without really knowing the consequences.
