DerStrom8
Super Moderator
Iv'e Posted a screen shot and a GIF of it working
Ah, I might see the problem. The outputs of the 4017 start at Q0, so output 1 is actually Q0. Therefore, you'll need to connect Q7 (which is actually output 6, as labeled on the chip) to reset the 4033. See if changing that helps. Also, for rolling the dice, I wonder if you'd want to speed up the second 555 a bit, so you can't easily see what number the display is showing until it stops. I think it'll make it look a little more random, but that's only personal preference. You can do whatever you want with it.
Regards
