Hi All,
I'm designing a capacitive mains power supply. I need to do single component fault analysis and have a few questions:
The circuit is a standard capacitor with inrush limiting series resistor affair, and uses bridge rectifier. The capicitor has a parallel bleed capacitor. The requirement is that the circuit should not provide any dangerous voltages to the user should a single component fail short or open circuit so:
1) Does this mean that I should double up on the bleed resistor (i.e. put 2 in parallel)? AFAICS if a single bleed resistor were to fail O/C then the capacitor could remain charged. Putting 2 in parallel would seem to pass the single component fail test.
2) Do I have to consider what happens if the inrush limiting resistor were to fail S/C? This could lead to excessive inrush currents through the rest of the circuit (for a very short time), potentially causing cascade multi-component failure.
3) I have to consider what would happen if any of the bridge rectifying diodes were to fail O/C or S/C. I've noticed in Spice simulation that I could get full mains AC voltage swing with double the AC peak voltage value on internal circuitry. Should I use an MOV on this? The reason for this is the capacitor charges to peak voltage and is unable to discharge due to the diode failure, and this voltage is 'added' to the internal swing. Adding an MOV effectievly prevents the capacitor from being charged so high under that fault condition.
Has anyone out there done full single fault analysis on capacitive supplies, and what steps did you take?
Thanks!
Mark.
Thanks!
Mark.
