MrDEB
you print the part id on top
I found .25mm is fine for traces unless your carring some heavy amperage?
a Laser printer is what you have to have for quality printing.
also look at purchasing a PULSAR system
has sveral sheets of paper, some green TFF film (fills all the little voids in the transfer)
the kit I purchased came with several copper clad boards.
you can use an iron but I found better results using a laminator.
look at newegg.com for a good deal on a laser printer.
Pulsar states - avoid the Brother or ? line of printers as the ink doesn't work as well.
avoid right angles and V intersections.
when I must use such angles I just put a filled plane around the intersection (see my post where I added filled planes.
check out the PULSAR website for info.
