jakeselectronics
The output will give 5 volts (providing the input is 5 volts) but the I/O pins on a pic can only 'sink' and 'source' up to 25mA. (See section 17 of the datasheet "Electrical Specifications")@ Jakes electronics, Thanks for the circuit I have got it to work What kind of voltage does each pin allow out to the component? If i was to create a circuit for a motor would I have to use a transistor?
Rhys
So the answer about having to use a transistor is yes.Maximum output current sunk by any I/O pin..........................................................................................................25 mA
Maximum output current sourced by any I/O pin ....................................................................................................25 mA
Anything over 25mA will need some type of transistor.
