Hi there
Her is the circuit I am trying to get working, but not successful.
I am seeking help with this problem. We suppose to connect a circuit with use of TL071,2 op-amps (which will be powered by +-15V) to an i-pod or some similar mp3 player with output around 1V. Now the signal is amplified and then divided into bass, middle, treble using low, band and high pass filters to light up LED for each part of the frequency (0 - 100, 100 - 1000, 1000- ... Hz).
Before the diodes I am measuring 20V AC or 10V DC which is sort of switching on and off according to the signal (which is good) so it should be lighting the LED’s. I am not quite sure what the diodes do to it although I am actually using different type from the diagram.
Thanks for any help or advice or explaining
R![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ps: Audioguru pls do not reply (do not waste your time by explaining basics) thanks.
R
