My Mod4 FM transmitter is wideband on the FM broadcast band.Whats the bandwidth on this transmitter? What would it take for me to adapt it to 2M?
The 2m band has audio that is narrowband and sounds awful like a telephone.
Far too wide.Whats the bandwidth on this transmitter?
Just need to reduce the number of turns on the coil.What would it take for me to adapt it to 2M?
I normally hear from 20Hz to 20kHz and narrow-band does not sound the same. The important sounds in speech (consonants) are well above 3kHz.PS dont worry about AGs comments about poor audio quality on 2 metres, he has a HiFi fixation, fo him all audio systems must have a flat frequency response from DC to daylight.
I believe that you are 60+ years old, in which case your hearing is exceptional.I normally hear from 20Hz to 20kHz
I listen to SSB on the air every other day, have done for the past 40 odd years, sometimes it helps the intelligibility of a signal swamped with noise to adjust the pitch to be slightly higher than normal.Didn't you hear the "ducks quacking" on the SSB radio recordings on a thread here?
Kennedy is a known good book on Communication systems Ganesan.hi.. can anyone reccomend me a good book for communication systems...
is simon haykin good... i d like to learn a lot about communications and networks... wat are the good self study books..
better remove the word "old" as we still feel that you are younger in technical abilities & mindset compared to youngest. long live AGWhen I was 20 I could hear the "ultrasonic" motion detector at the museum. It played 24/7 because it was "not audible". It was deafening.
No, I am not a girl and am not a dog. Instead I am a dirty old man.
I can still hear some CRT TVs whistling at 15.7kHz.
I could hear that the new speakers at the concert hall and stadium sounded bad.
I could hear huge differences between different tweeters.
I have never had my hearing tested because they don't test higher than only 8kHz.
