Don't you mean 141mV p-p?Roff said:In his first post, Patroclus says the sensitivity is 50mV rms. This means he needs a 100mV p-p square wave (AC coupled - DC doesn't count). I doubt the spec applies to any waveform other than 50% duty cycle.
That's true, the cable if already matched to the input impedance of the counter and adding a resistor at the counter end would mess that up.If you are going to use a series resistor, it needs to be applied at the source, to minimize reflections in the coaxial cable.
A 141mV p-p sine wave has an RMS value of 50mV. A 100mV p-p square wave (which I specified) has an RMS value of 50mV.Hero999 said:Don't you mean 141mV p-p?
OK, here's the deal. Waveform distortion due to reflections only occur if the source termination and the load termination do not each match the characteristic impedance (Z0) of the coax. Let's assume the coax has Z0=50 ohms. If the load is exactly 50 ohms, with no reactive (capacitive or inductive) component, then the load will completely absorb the incoming wave, and no reflection will occur, regardless of the source impedance. However, if the load is mismatched, then a portion of the signal reflects back to the source. If the source is exactly 50 ohms, it will absorb the reflection. So, even though there has been a reflection, there is no waveform distortion at the load (where it matters). However, if the source is also mismatched, a portion of the reflected wave will travel back to the load, distorting the waveform. For these reasons, a well-designed coaxial transmission system will attempt to match Z0 at both source and load.patroclus said:I'll take advantage of the opportunity to get something clear.
When I studied microwaves, the teacher told us that at high frequencies, when the wavelength of the signal approaches the size of the components in the circuit, the reflexions have to be taken in account. So, impedances should be matched to achive the maximun power transfer to the load. Ok, this also applies in any circuit at any frequency, even in DC. Impedances should be equal. But, no reflexions happend if frequency is not high enough.
From that moment, I started to see a microwave circuits as a different kind of circuit than "standard" AC circuits, where reflexions don't happend (or are negligible). Now, relating this to what have been said, I suppose I need to use a 50 ohm coaxial cable for frequency counter 50 ohm input, and a 1Mohm oscilloscope probe for the high impedance input.
Now, as Roff talked about reducing the reflexions in coax cable, should I suppose that they do happend at 100 MHz - 300 MHz frequencies of an hipotetical CMOS bus / signal ?
If they do, then a impedance far away from 50 ohm would cause a terrible standing wave ratio,... maybe I'm confused. To be honest, I didn't like microwaves too much
The load on the circuit side doesn't have to have a 50 impedance because all the energy would be absorbed at the counter end.
I explained this once already:patroclus said:If a common value for TTL's IOH is 400 uA, driving a 50 ohm load would cause a mere 20 mV voltage drop.
If you use a 1950 ohm resistor in series, as you proposed, you'd get a 2k ohm equivalent load, and 0.8V drop (400uA * 2000). But the voltage divider 1950 + 50 puts no more than 20mV in the 50 ohm input.
Remember that 400uA is at 2.8V, not 400uA at 0V, and it is worst case.The output of a TTL gate does not look like a 12.5k resistor. I realize you inferred this from the 400ua output sourcing current spec, but this is the worst case, and is specified with the output at 2.8V. I tested a 74LS04 on my bench, and at 25MHz, it drove about 3V p-p into 560 ohms, and over 1V p-p into 47 ohms. So, if you put a 510 ohm resistor in series with your output (put it on the end of the coax that goes to your TTL gate, not on the freq meter end), you will still have marginally valid logic levels on a typical gate.
I just gave a range of values, you should adjust them to suit your meter, generally higher values are better than lower values as there's less chance they will interfere with the operation of your circuit.patroclus said:If a common value for TTL's IOH is 400 uA, driving a 50 ohm load would cause a mere 20 mV voltage drop.
