Fried inverter
Whatever you're using to cover the board with has a very poor dielectric breakdown voltage apparently or is otherwise directly conductive. You have to use a proper sealant, one specifically designed to withstand high voltages and make sure it's cured/set completely before testing.
How about Red Glyptal insulating enamel?
Andy
4pyros suggestion you test it under load is probably good too, the no load voltage of those things should be considerably higher than it's loaded voltage.
