My wife's brand new German car has 15 inch wheels.
Like this?But those tires on the wheels are measured in millimeters for the width! I'm surprised too that they are only 15 inches, most modern cars start now with 16 inch wheels and go up from there.
Not so much. The bigger rim and lower aspect ratio(height above the rim) gives better mileage, or at least that is the claim. Plus they allow bigger diameter brake disks for better stopping.The big rims and less tyres is basically just fashion.
Like this?
In a lot of cases, the larger diameter wheels don't come with larger brakes. For instance on my car, all the variants of that model have the same brakes, and 16, 17 and 18 inch wheels are used, so while that is a theoretical advantage, it's not often used. All modern cars have brakes that can make the ABS operate on dry roads.Not so much. The bigger rim and lower aspect ratio(height above the rim) gives better mileage, or at least that is the claim. Plus they allow bigger diameter brake disks for better stopping.
Not in Australia, it comes in cubic meters. Also, when I concreted my first drive about 40 years ago in the UK, it came in cubic meters too.You order concrete by the yard. You get cubic yards.
Where as my 1951 A40 Devon had a 1200cc engine, although I forget what size the spark plugs were, but they would have been imperial as they were the only spanners and sockets I had at the time.My 1953 British car has a 1.25 litre engine, and the spark plug threads are 14 mm.
I would strongly suspect that the A40 also used M14 x 1.25 mm threads. The size of the hexagon was probably imperial. I think that spark plugs were usually 13/16".Where as my 1951 A40 Devon had a 1200cc engine, although I forget what size the spark plugs were, but they would have been imperial as they were the only spanners and sockets I had at the time.
I'm not sure how the lower aspect ratio affects the mileage. The lower height of the sidewall will have to be distorted to a smaller fraction of its normal height, and I thought that would increase the rolling resistance. I know that run-flats give worse mileage because the sidewalls are so hard.
What about 'metric' pipe sizes?I would strongly suspect that the A40 also used M14 x 1.25 mm threads. The size of the hexagon was probably imperial. I think that spark plugs were usually 13/16".
I just used my spark plug socket, which was only used for that, so it didn't make much difference to me what size it was.
I heard somewhere that Bosch had a patent for spark plugs, and one of their licencing conditions meant that M14 x 1.25 mm was used by all manufacturers.
That reminds me, the metric sockets that I've used on all the cars I've owned that were built in the last 40 years, are all 1/4" or 1/2" square drive. 3/8" and 3/4" are also available, but I have very few of either. As far as I know, there is no such thing as a metric square drive for sockets.
Confused about Metric and Imperial Pipe Sizes?
When the industry moved from imperial to metric sizing it was done in an uncoordinated fashion.
Consequently sizes are different for plastic and steel product
