I was looking around for a low Vbe transistor to use as a switch. Germaniums had a low Vbe but are hard to come by now. I'd rather not have to use an OPA comparator, any suggestions?
Well, it's a bit of an experiment, but I want to use a transistor to act as a current limit for a P Fet. The P FET Rds on is around .17 ohm, I'd like to limit the current to around 2 amps without adding more series resistance. So a .34 Vbe is too low for silicon transistor switching.
you're kind of doing this backwards, since reducing the current through the FET (by reducing the gate drive) INCREASES Vds. if your current limiter is not the FET, then it might work. you can use an op amp to sense Vds across the FET.
