ljcox said:It would be better to eliminate R3. I expect that the person who designed the circuit that was in the book was one of the "transistors are current controlled" school.
But in fact, they are voltage controlled.
It's an often argued point - but current 'controlled' makes a LOT more sense - and the transistor manufacturers even specify the current gain of their devices.
Asserting they are voltage 'controlled' makes very little sense, and just confuses the issue.
By simple ohms law it's blindingly obvious that you MUST have a voltage for there to be a current - so in that respect there is a voltage.
However, the fact remains, that a transistor base requires current, and the device gives current gain based on the current input to the base. Most of the world considers a transistor a current amplifier for this reason.
An FET on the other hand is a voltage 'controlled' device, you apply a voltage to the base, and the drain current varies accordingly - the gate draws no current, so just like a valve/tube it's a voltage driven device.
