Giant font function for GLCD 128x64 (OshonSoft Basic)
DogFlu66
I leave the function to generate giant characters on a 128x64 GLCD.
'Giant characters function for GLCD 128x64.
'Pic18F46k22, OshonSoft Pic18 Basic Compiler v8.42
'By COS, 02/2023
#define CONFIG1L = 0x00
#define CONFIG1H = 0x28
#define CONFIG2L = 0x1e
#define CONFIG2H = 0x28
#define CONFIG3L = 0x00
#define CONFIG3H = 0x3f
#define CONFIG4L = 0x80
#define CONFIG4H = 0x00
#define CONFIG5L = 0x0f
#define CONFIG5H = 0xc0
#define CONFIG6L = 0x0f
#define CONFIG6H = 0xe0
#define CONFIG7L = 0x0f
#define CONFIG7H = 0x40
#define CLOCK_FREQUENCY = 64  'Clock 64Mhz
Define STRING_MAX_LENGTH = 30
Define SIMULATION_WAITMS_VALUE = 1
Include "_FuncionesPic18F46K22.bas"
Include "_FuncionGlcdBigFont.bas"
MAIN:
    'Clock internal 64Mhz.
    Call _setup_oscillator(_osc_16mhz_hf)
    Call _setup_oscillator_mode(_primary_clock)
    Call _set_pll4(_pll_on)
    Call _interrupts_mode(_disable_priority)
    'PCB configuration
    AllDigital
    TRISA = 0x00
    TRISB = 0x00
    TRISC = 0x00
    TRISD = 0x00
    TRISE = 0x00
    'Configure puerto GLCD
    Define GLCD_DREG = PORTD
    Define GLCD_RSREG = PORTB
    Define GLCD_RSBIT = 4
    Define GLCD_EREG = PORTB
    Define GLCD_EBIT = 5
    Define GLCD_RWREG = PORTB
    Define GLCD_RWBIT = 3
    Define GLCD_CS1REG = PORTB
    Define GLCD_CS1BIT = 1
    Define GLCD_CS2REG = PORTB
    Define GLCD_CS2BIT = 2
    ConfigPin RB0 = Output
    Symbol GLCD_RESET = RB0
    GLCD_RESET = 0
    WaitMs 10
    GLCD_RESET = 1
    GLcdinit  'Initialize Glcd
    'Assign names to the Leds
    Symbol Ledgreen = LATC.0
    Symbol LedOrange = LATC.1
    Symbol LedRed = LATC.2
    Symbol backlight = LATE.2
    Dim _High As Byte
    Dim _Width As Byte
    Dim x As Byte
    Dim y As Byte
    Dim number As Word
    Dim _String As String
    Ledgreen = 0
    LedOrange = 1
    LedRed = 0
    _String = "THE END"
    number = 0
    _High = 4
    _Width = 2
    WaitMs 3000  'Delay in mSec.
    x = _glcdwritebig("Number:", 7 * 2, 0, 2, 1)  'Write text
    While True
        Call _glcdwritebig(#number, 0, x, _High, _Width)  'Write text (number)
        number++  'Increase number
        If number > 15 Then  'If finish counting Stop
            Call _glcdwritebig(_String, 56, 40, 1, 1)
            While True  'Infinite loop
            Wend
        Endif
        WaitMs 500  'Delay in mSec.
    Wend
End
Video:
  • _FuncionGlcdBigFont.bas
  • _FuncionesPic18F46K22.bas
I presume you are aware that the Nokia 5110 IS a graphics screen?.
Hi N,
Thanks for reminding me, that the 5110 is a graphics screen, I'm used to it as only text, though.
I was thinking of this type:
C
Hi N,
C
No text on a 5110 - it's graphics only, and you have to draw the text yourself, including providing the font :D
The TFT screens are a lot more complicated, and use much more memory - you've also got zero hope of a screen buffer, which is what you usually use on the 5110.
Hi N,
Yes, back around 2017 E wrote me CODE for this very thing, so somehwere here you'll find it all.
Start with: https://forum.allaboutcircuits.com/...l-by-location-pic-in-oshonsoft.148795/page-16 #318
C.
