Moving from mikroBasic to OshonSoft Basic
A/D coversion and the entire code simulation is ok, except when values for AN0 are set small.
Then the LCD does not show "Input is too low".
P.S.: The logarythmic signal detector (ahaed of the MCU circuit) output is ca. 0.45 VDC (broadband noise signal) without any input signal applied. In this case I want to display the above message.
again:
Lcdcmdout LcdClear
ADC_Read 0, ADCRead 'Result of A/D conversion from AN0
ADCResult = ADCRead*5/1024
Lcd_Out(1,1, "ADC OUT = " + #ADCResult +" V")
If ADCResult<0.5 Then
Lcd_Out(2,1, "Input is too low")
Else
dBmResult = (ADCResult-ZEROXING)*SLOPE
Lcd_Out(2,1, "PWR = " + #dBmResult + " dBm")
Endif
WaitMs 500
Goto again 'Make a new A/D conversion
Goto main
End
Well, I have tested the program in more detail and it seems that in these new versions of the compiler ADC_Read configures the pin as analog and as input. I thought that the problem was that the pin was not output as analog in the simulator. Anyway, if you wanted to do this, it does work.
I didn't see this configure the AN0 pin: Sub GlobInit.
  • V_dBm_Meter (1).bas
Gentlemen,
My project works (simulation and hardware), mission accomplished.
Thank you all who contributed with advice, and help.
I have learnt a lot and will continue exploring OshonBasic.
Best regards,
Robert
I want to eliminate the 0.01 dBm variation on the LCD display that happens for a constant input RF signal level to the ADC of the circuit. The ADC conversion slope is 19.61 dBm/Volt.
Therefore 0.1 dBm level change is caused by 0.1 dBm/(19.61 dBm/V) = 5.1 mV change in the analog input voltage.
My goal is to keep the display value unchaged for 2*5.1 mV = 10.2 mV, i.e. <= 2 bit change in ADC output.
Please find attached the source code. Would the error message mean that the syntax "abs" is not known in OshonBasic? Any cure for that?
  • V_dBm_Meter v3.bas
The only way to "eleminate" this tiny variation is to over sample.
If you are running at 5V a bit change is 4.88Mv. Then you need to decide how to get the best information to screen.. You set your decimal places to two.
I do not use floating point numbers on small devices as I know how they work and its not how you think.
lets take your calculation 2.5V should be 512 bits.. 512 * 5 = 2560 / 1024 = 2.5v BUT!!!!! ADCRead is an interger only the result is floating so it may need casting.. Vlad does allow casting
So
adcread = adcin(0) * 5 'integer multiply
adcresult = adcread ' basic cast to float
adcresult = adcresult / 1024 ' now it works..
But!! you want MORE precision
do this
for idx = 0 to 10
adcresult = adcresult + adcin(0)
' you can place a tiny delay here to slug readings
next idx
adcresult * 5 / 10240 ' gives 2.5V
You can play around ie read adc 5 times then times by 100 then / 10240
The point is the output will be more stable.
Dim ADCRead_New As Word 'Integer/Longint 'ADC output
Dim ADCRead As Word 'Integer/Longint
They are declared as unsigned integers. Since they are declared as unsigned integers the result will always be another unwanted unsigned number.
You have two options either you declare them signed or you have to apply a temporary conversion type to the variables.
If ABS(CInteger ADCRead_New - CInteger ADCRead) < 2 Then ADCRead_New = ADCRead 'type conversion.
' Math.bas
' Name: ABS
' Description: Calculates and returns the absolute value of a given number.
' In: Signed data
' Out: Longint
' Version: 1.0
Function ABS(numBer As LongInt) As LongInt
'If the number is negative, change its sign
If numBer < 0 Then
ReturnValue -numBer ' Returns the opposite of numBer
Else
ReturnValue numBer ' Returns the number unchanged if it is not negative
Endif
End Function
Sorry, I meant to say "I want to eliminate the 0.1 dBm variation" in my previous message.
As I said... ANY output variance can be eliminated by over sampling.
Oversamling relies on noise to correct the reading.. As I said take 2.5v should yield 512 bits
as a bit is 4.88mV it shouldn't affect the voltage to 2 decimals as 513 2.505V or 510 2.495V . But
read in 4 readings 513, 511,512,510.. then and add together = 2046 then back to 10 bits 511 but much more stable.
I oversample my ADC 24 times then / 6 thus I have a pretty decent 12bit result..
Ian Rogers wrote:
"read in 4 readings 513, 511,512,510.. then and add together = 2046 then back to 10 bits 511"
Isn't 511 = %111111111, i.e. 9 bits?
Hi Nigel and baz... Up the 10 bit adc by over sampling to nearly 12 bits, then divide by down to 10 bits.
I was using half scale as the example.
When I over sample I keep the ADC result at 24 bits.. Then do any mapping to get the best result possible.
As everyone else does...
This may be easier for you to implement:
Const NOISE_ADC = 10 'Noise level expressed in ADC points.
ADC_Read 0, ADCRead
main:
Gosub GlobInit
Lcdcmdout LcdClear
WaitMs 100
Lcd_Out(1,1,"RF-Power Meter")
Lcd_Out(2,1,"Hardware Rev.4")
WaitMs 500
Lcdcmdout LcdClear
again:
ADC_Read 0, ADCRead_New 'Result of A/D conversion from AN0
Call Error_ADC(ADCRead, ADCRead_New)
End
Proc Error_ADC(radc As Word, ByRef radc_new As Word)
Dim error As Integer
error = radc - radc_new
If error < 0 Then error = -error
If error < NOISE_ADC Then radc_new = radc ' Discard the last adc reading.
End Proc
I just wanted to check if the summing up (10-times loop) works correctly.
What is wrong with this?
It compiles for me, you may have an older version that doesn't allow that operation with "integer". I think the problem may be your compiler version, try updating your IDE or upload the code and I'll review it.
Hello DogFlu66,
My version is 5.72, and I want to update to the latest (v5.76).
Do I have to uninstall the present version prior to installing the new one?
I can't remember, is there a download page for registered users or would I have to install the time limitted version (exe file)? I do have the registration zip file of course.
Please find attached the latest source code.
  • V_dBm_Meter v4.bas
I'm on the 5.76 IDE (NOT the Basic Compiler), and I get the same error. It might have something to do with concatenating a string with a floating variable who's length is undetermined.
However, even trying to print a simple string, I get the same error. Thus it seems to have something to do with either the function definition or variable definition.
This could also be a bug in the IDE version vs the Compiler version.
If I change the line to read:
i = Lcd_Out (1,1,"ReadSum = " + #ADCReadSum)
then it compiles and all the other LCD_OUT compile ok as well. There seems to be some bug with the very first call to that function. Subsequent calls seem to be ok.
Lcd_Out(1,1, "ReadSum = " + #ADCReadSum) 'Ok
Ok, it compiles fine, after the name of a user-defined function "Function and Proc" there can't be a space between the name and the parentheses.
FunctionName+space+(argument) = error.
