Hi Ron,
Well i dont think so as that name does not ring a bell at all. Why do they have some good TV's there?
BTW i like Home Depot but i just wish the hardware stores could have stayed around too.
Hi again,
Lawrenceville is still a little far from me and i would not want to go that far for a purchase like this.
I saw a "Sceptre" on sale for a very good price. Ever hear of that make/brand?
BTW if you have read my other thread about fixing a TV, i have found the problem and replaced some caps and have more caps on order to complete the repair, and it's already working now, but i am still looking around for another one that is more modern for one thing and probably bigger screen. The one i have is 5 years old, but that's 50 years old in LCD television years
Yeah i guess you are right about that. I had a Sony monitor (CRT) that only lasted 1 year. I have a cheap AOC TV that lasted 5 years before the caps blew out.
Yes i agree, for a casual analysis. But for me it was very significant because the Sony was quite expensive
The Sony was one of those CRT's with the 'line' or "lines" across the screen, which was a very thin wire internal to the CRT.
That's a 'feature' of the Trinitron tube, instead of a shadow mask it uses an array of vertical wires, and the two horizontal wires are there to provide support for those.
Nigel knows his Sony stuff in abundance. And is always at the top of his game.
Awesome stuff. Sadly, not many Sony CRT's left here.....just Ching junk.
When a Trinitron tube is working properly (and the chassis driving it).....no better CRT picture is possible. Black is pitch black in all the right places and white is absolutely white.....contrast and picture quality are awesome. Heck, even the 191 did it way back in the late Seventies here....
The 191/2 was a set that was "nervous" to watch though...you never knew if and when GTO's would get cross and that famous humming sound "hmmmmm"....dead set. PSU and Line stage blown...dead set....tube fine.
Some interesting stuff here. I read up on the Trinitron tube years back when i had that model where i found out the larger sets had two horizontal wires and the smaller ones one horizontal wire, like mine.
The thing that was strange was that the wire(s) are not visible normally when watching a TV set with those wires, but for close up computer monitor work (like mine was) you could see the wire. I had to adjust to that by incorporating that wire into my desktop where i would put certain icons above the wire and certain other ones below the wire. The wire on that model was about (roughly) 75 percent up from the bottom (25 percent down from the top) so it divided the screen up into two regions. I got very used to having it there.
And i guess i found at least one other person that appreciates the beauty of a display that can accurately display whites and blacks, especially the deep blacks. I had a hard time explaining this to people a long time ago. On my cheap AOC TV set, the blacks are grey, and when there is a dark scene the dynamic range is very limited so the blacks get mixed in with the greys (as they appear to be the same color) and you can not make out faces and other detailed objects. That's the worst thing about the TV, and i am hoping that the newer models have better dark level contrast. I am hoping that the LED backlighting has helped this problem.
I also read about dynamic LED backlighting where different regions of the screen can change the backlighting independently, so if you have a darker picture on the left and lighter on the right the LEDs on the left will be dimmed more than the ones on the right. Perhaps one of you knows if this feature has been used in any TV sets already.
I had suspected that the more recent ones were edge lit to save space. I like that too though, less space and lighter weight. I have a 24 inch LED backlit monitor that i can pick up with two fingers...i was lucky if i could pick up my 15 inch Sony Trinitron monitor with both arms.
