Good points. Low current contacts are very fussy. Usually the material of the contacts allows it to function at low currents. Wiping can remove the oxide as well, but so can a current around 10 mA. 10 mA isn't likely with an audio signal.
Yeah, that's a good idea. I just want to be proactive and buy some replacement caps just in case, so if it does turn out to be the problem (however small a chance it seemsThis thing is an amplifier, so inject and trace. Binary search. I verify the beginning, then the middle, then half of that etc.
So, unless your re-capping for another reason, I'd say troubleshoot.
Seems like it would be easy enough to isolate the faulty stage with a scope.
