Another issue is that the output of the PLC is 24V+ for pulse and the logic gates input have a maximum of 7V+. So I will have to modify the circuit with a transistor circuit similar to what you had in the original design on post #25.
You are quite right about 24V being too high for a 74 series logic gate input, but if you post details of the PLC output it should be possible to do a simple interface.
(not to mention that I still can't get the gates to work)
Logic chips are the way to go- simpler and faster. The logic circuit is very simple and should not cause you any problems?
spec
