clinot
The goal is to create a circuit that activates a solenoid when the supply power is cut, using power stored in a capacitor. So far the issue I have been running into is that the relay is energized by the capacitor when power is cut, and the solenoid on NC remains stationary. If the ground for the relay coil is removed at the same time that supply power is cut, then the circuit functions as intended, but so far I have only been able to do that with a manual button/unplugging a wire. Ideally it would all function on a single power input, rather than needing a control input as well.
Thank you for the help!
