Help in reduce circuit losses
GH Crash
Any suggestions on how to reduce the resistance of the attached circuit.
A supercapacitor (EDLC) is used to power a small motor. There is an ATTiny85 chip in the circuit that is used as a timer and a PWM controller for the motor. The problem that I'm loosing about half a volt between the capacitor's voltage and the voltage across the motor's leads. I need to minimize losses in the circuit as much as possible.
Can you suggest means to reduce voltage loses to the motor?
Thanks to all of you who have responded. Not only has your responses improved every component of the circuit, it has greatly increased my knowledge level.
Let's call this thread ended. But I'm sure I will have other dumb electronics questions in the future.
