Mr RB
What we were trained to do was to put 10 ohm or 22ohm resistors in the supply rails (often in place of the fuses), then if the amp had a fault or severe bias arror etc a resistor would start to cook and make a bit of smoke, but no transistors would be killed. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Once the amp had been tested with a sinewave and no load (or a light load) the resistors would be replaced with fuses and a proper load connected. Often smaller fuses for the first tests!
If people in your school are destroying FETs all the time the teacher might need to suggest a better methodology.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
