Overclocked
You could use bondo or JB weld to keep everything together. If you use JB weld they will have to use a cutting tool to get in.
andrew12345678 said:my uncle designs and builds proto types in a company workshop and he told me that every month the equipment they use is tested and before its tested some of the immature workers there get some really large capacitors and hook them up with reverse polarity to the power supply and hide them. When the testing people turn on the equipment there is a loud bang and white stuff goes every where.
now, the relevance of this is u could do a similar thing with the explosive idea but instead of explosives conect all your capacitors up and when they open the case bang! the capacitors are gone and it may take out more components.
you could put the etching solution in the container in an easy to break bag, when its opend the fluid will cover the circuit board nd no more tracks.
To protect from X-Rays use led
just some ideas
spuffock said:A couple of sane ideas for prototypes.
1) after grinding off the chip numbers, chamfer the pin1 ident off, bend the legs through 180 degrees, and chamfer near pin 16. Then fit to the mirror image footprint on the board. One chip in 20 will be enough.
2) take a few diodes and burn them out to open circuit. Then fit them in places where the presence of a diode would be catastrophic. Once again, don't use too many.
3) Use a mix of base versions of transistors, ie bc183, bc183L.
Pot the whole thing in epoxy.
If anyone reverse engineers this, they would have better used their time designing a new one.
Megamox said:Sounds like patenting an idea might end up costing me a fortune!
Im gonna try out the glue gun approach, and get hold of some epoxy resin and some potting compound and see how i get on with a trial board![]()
I did like the diode idea but i havent been able to get one to go open circuit, so i just frantically wiggled some jumper wires up and down in the middle until i felt the conductor beneath the insulation break (open circuit) and then just connected them all over the place!Anyone copying the design should go crazy trying to figure out how its even working!
Megamox
Megamox said:All i really know about patenting, is that it protects your idea's from being copied
Megamox said:All i really know about patenting, is that it protects your idea's from being copied, but does that mean you can patent any idea/circuit design you have?
Surely someone out there could have come up with the same design before u and you're actually copying them without knowing!
If i patent the potential divider does that mean everytime someone uses it in their circuitry i get paid a fee![]()
Megamox
