vinodquilon
Here I am presenting my first serious practical work in Cadsoft Eagle
with a very simple circuit.
See the attachment.
Help to optimize my work by pointing any faults (if have) in my work.
I Used the schematic as reference to place components.
I used wire width 0.024
Is it enough for etching ?
Four wires are drawn on component side. But this is one sided board.
So I will connect four direct wires (without soldering) on component side between desired points.
After auto route (Preferred directions 1 Top-N/A, 16 Bottom-*) these four
wires remain unrouted. Its manual routing on solder side is so tedious as of crossings.
So I manually route them through component side. That is wire jumps.
Does it is a good practice ?
Does there any need for turning on/off any additional layers on component and solder side ?
I heartily welcoming all opinions to improve my skill in Eagle PCB fabrication.
See the attachment.
