help with a project in pic16f877
Sara6451
You need to get a number and according to the received number output a square wave with a different timer
  • מיקרופרוססורים - pic16f87x - datasheet - 342230 (3).pdf
Break the problem into parts.
1) First get the number into a variable, thru GPIO port or UART or I2C or.....
2) Setup a timer to run and toggle a gpio pin to create a square wave, confirm the timer
is running and toggling the GPIO pin. Pick the clock for the timer and set that.
Timer mode setting, triggered or continuous.....
3) Scale the number you received, its range of value, to the timer period range
4) Update timer period with 3)
So you need a variable to hold number received and one for the scaled/translated number
for the timer.
Read the timer portion of manual. How it operates, what registers you need to set
to get it to run. Read that portion at least twice. Do same for GPIO pin & port control.
Decide how you will use timer to signal changing the GPIO pin, using polling or an
interrupt.
Just a few of the steps.....
Regards, Dana.
A rather dated micro, BTW.
Yes. After all the 741 is still used for students labs today.
