Help with high pass filter in bass guitar
Scornn
You could just add a capacitor in series with the signal connection (green) from the volume pots to the output jack.
Add a pot or switch across the capacitor to bypass it or adjust the effect.
I'd start with a cap of the same value as on the tone control & see how that works? It will probably take a bit of experimentation to get the best sounding effect.
You could use a could use a couple of plugs or a plug and socket to initially experiment, with the capacitor in series with the signal wire & ground/screen linked through, external to the guitar, to work out the ideal value and control circuit, rather than keep re-modding the guitar itself?
(Or put it in a small box inline with a short cable for use when needed).
Not quite; like this:
The metal case of the pot should be connected to the case of one of the other pots (or ground/screen), but all three terminals are signal connections and not grounded.
