technogeek
Well then..... I guess there isn't two ways about it, I'm stuck into building two switchers.
You can still do it with just one switcher. All you need is a low value resistor in each string to equalize the current between them. The resistors only have to drop a few volts so they shouldn't have to dissipate too much power. If you match the voltage drop of both LED strings as close as possible, you can use lower resistance and thus waste even less power as heat.I'm stuck into building two switchers.
kchriste said:You can still do it with just one switcher. All you need is a low value resistor in each string to equalize the current between them. The resistors only have to drop a few volts so they shouldn't have to dissipate too much power. If you match the voltage drop of both LED strings as close as possible, you can use lower resistance and thus waste even less power as heat.
You probably won't find that much of a difference between LEDs if they are from the same batch. The 100 white LEDs I bought had a Vf spec of 2.75-3.80V but when I tested about 30 of them at the nominal current, they were all within 0.15V of one another.I'm not interested in matching LED's for hours and hours....
If he really wanted to, he could use a voltage doubling circuit on the input to give him enough headroom for a single string. Two diodes and two caps is all that is needed for the voltage doubling / rectifier circuit. This is a common technique in computer power supplies (Switches between a doubler and a bridge circuit) to give you a 110/220Vac option via a switch.I would drop the two-string idea competely, frankly.
That's true. He would have to physically arrange the LEDs on the heatsink (If he can isolate them electrically) so that one string is interleaved with the other so that, on average, the strings are at the same temperature. The best solution, as you pointed out, is a single string....Two strings will go out of balance since the warmer string will develop a lower Vf, thus stealing more than half the current.
justDIY said:I seem to recall seeing diagrams from lumileds or perhaps philips (for their xitanium driver) showing suggested wiring of series-parallel arrangement. The series strings were wired in parallel across the supply, and crossbars were used to link the two strings between each LED.
I supposed the purpose of the crossbar was to normalize voltage on the two strings, preventing any one abnormal led from causing a current hogging scenario.
I'm searching for that info again, will post the link when I find it.
edit: looks like LuxeonStar.com summarized the application note here:
Oznog said:I prefer the Lamina devices myself. Outrageously flat and an electrically insulated backing of pretty decent size.
I noticed that the 10mm LEDs have evolved into ones with HUGE ratings. I ordered some off a guy on eBay with a 150,000mcd rating over 30 degress! I mean, holy crap! They use multiple dies in the package, which precludes a tight focus. I'm still waiting, they came from China so it's expected to take awhile. I only paid $5.62 for 5 of them though.
