Help with selecting alternative components
danrogers
Hi all, I'm just tying up some loose ends on some college stuff and something I still have to do is to find three replacement (more modern) components for the following ( I think TTL) IC's:
7404
7414
7400
From a fair amount of googling, I have failed to return much infomation about these IC's, hence Im struggling to find more modern replacements.
Thanks in advance for any help!
7404
7414
7400
All the devices are older TTL.
The 7404 is a hex inverter, the 7414 is also an hex inverter, but has Schmitt inputs.
The 7400 is a quad 2 input, NAND gate.
Equivalents can be found as 74LS04 74LS14 and 74LS00
Hi Eric!
Thanks very much for that, great stuff.
Just for my own knowledge, what are the main differences between the outdated and the more modern IC's?
Thanks again!
Hi Eric!
Thanks again!
The LS tells the story, Low power Schottky
Lower power consumption and faster switching.
There are a range of 74HC and 74HCT devices that use even less power also CMOS types HEF4049 [7404] HEF40106 [7414] and HEF4011 [7400]
Try Datasheet & Application Note Database, PDF, Circuits, Datasheets | Datasheet Archive for datasheets of specific IC's
Also this is handy:
http://www.interfacebus.com/voltage_threshold.html
Just to be clear, the 74HC and 74HCT devices are CMOS types as well, but are faster and have a lower operating voltage range then the old 4000 series devices.
hi Carl,
My post does say 'also CMOS types'.
I have suggested to the OP that he gets the required datasheets and I have posted a web link.
Regards
