So full-speed run current is ~1.8A; nearly twice that of the old pumps. Useful info. Presumably the PDM trimmers are set somewhere near their max to prevent the trip operating?the sticker on the back of new pumps say 40W.
Is the low ohm resistor Rsense?
That tells us the over-current sensing in the PDMs isn't triggering the alarm; rather, it's the under/zero-current sensing in the FSM which is doing it.The only time the alarm has sounded is when the tide pumps are in reefcrest or one of the other variable flow modes, in which case it does not seem to matter where the PDM trimmer is set.
The Alarm section can be extended easily adding a respective 'LED + diode' string for each new PDM.
Sure. Same principles as the existing one. Give us a shout if you need help on that.Would it be OK to make a seperate alarm module
There's always a "but"But every five miutes or so .....
Spot on. Useful info re the Rsense voltage. If that mod doesn't do the trick another option, admittedly more involved, would be to increase the value of each of R3 to R6 in the FSM.Am I on the mark here?
Aint that the truth!There's always a "but"..
Presumably the new controller does something different when the pumps are on high. Perhaps a soft start? Odd, though, that it's just for one wave pump and not the others. That could be due to a slight difference in the pump itself, or in the grounding path, or in the Rsense resistance in the PDM, or component tolerances in the FSM.It's funny how that mod worked for the alarm sounding on the tide pumps on reefcrest mode, but not on the little chirp from the wave pumps on high.
