alec said:The ground leg of the 12V regulator is probably the best point for linking the heavier conductor PowerGnd wire to the lighter conductor SignalGnd wire.
OR you can take it all the way back to the power supply (-) terminal.
Everything is soldered really tight to the board-the legs are bent and soldered-so I'll be starting from scratch.. I was assuming you'd salvage bits from your present build; or will you be starting from scratch? .
Makes sense. Heavy duty jacks and plugs it is.It only makes sense if the pumps are still under warranty. They'd be better fitted with heavier duty plugs and corresponding sockets for reliability. Just for testing you can probably get away with the present connectors. Just watch out for smoke signals.
Salty:
Do yo know about www.mouser.com (TX), www.jameco.com (CA), www.digikey.com (Minnesota) and www.newark.com (IL)?
Allied electronics is more of an industrial supplier of electromechanical parts: https://www.alliedelec.com
Everything is soldered really tight to the board-the legs are bent and soldered.
Alas, I can't get that sim to put out more than 15V and a current of 800mA, and only then if the pump resistance is modelled as 18ΩIf we set L1 = 3.4mH and series resistance = 2.14Ω (the actual measured values for the pump) then the output drops to a 0-4V oscillation at 2.5kHz
I think we may both have the same problem with the 500 ma 317 model. But having said that take a look at the LT1084 instead. I think it is 5.5 amps minimum. If not enough go to the 1083. The inductor model is not really to good as the the pump circuit probably won't turn on until it has 4 or 5 volts across the pump and the inductance with the rotor installed is probably closer to 10 or 12 mh.
The motor FETs are probably okay at 10 amps for a couple seconds, but who knows.
Sorry I am late I was out doing fireworks today.I have no practical experience of resettable fuses so will start another thread to seek advice.
Suggest 19AWG from 24V power supply input to TAM and for any connection to PowerGnd; 22AWG for the remainder.I have 19 gauge single strand wire, should I solder that to my heavy duty jacks?
I like that. Good idea. (Joe, the PTC is the resettable fuse).Or maybe kill two birds with one stone and mount the PTC in thermal contact with M1 since PTC's also trip by heat?
I think it's stretching things to call the circuit PCM when the pumps are only switching every 30 secs or soAlso, can't the PCM circuit us just a normal diode forward biased instead of a zener for the trip circuit?
Good point. I'll re-run the sims with that value, but it seems to be resistance which dominates anyway.the inductance with the rotor installed is probably closer to 10 or 12 mh.
I think it's stretching things to call the circuit PCM when the pumps are only switching every 30 secs or so.
Using 10mH instead of 2mH as the coil inductance value had very little effect, except for a slight increase in current rise time at t=0.
It's only important for inrush current and running current should you ever need it.
Using a 1084 (or presumably any other 3-terminal linear regulator) as a controlled voltage source for the DPM-Mk2 introduces the problem of heat dissipation. With a stalled rotor and with the ADJ input of the 1084 grounded to minimise the 1084 output voltage (and hence the pump current) the 1084 will dissipate 13W unless something else (hey, what about a FET!) is added to switch it off completely. With a short-circuit the 1084 dissipation is 18W.
During locked rotor and the input grounded the output is only 1.4 volts. So the motor FETs won't turn on.
With short circuit the built in short circuit protect takes over.
But the FET is fine. I was just concerned about the motor FETs having a go at 9 amps for a few seconds.
Here is the best P FET I could find at Mouser with a 30 volt gate to source rating in a DPAK. Do you think it can handle 10 watts? If so just put the fuse in, put a low current alarm across it and let it cycle.
https://www.electro-tech-online.com/custompdfs/2012/06/FQB22P10TM_F085.pdf
Probably not. I guess it depends on the unknown FET spec. Could they turn on partly?During locked rotor and the input grounded the output is only 1.4 volts. So the motor FETs won't turn on.
True, but there's still the little problem of getting rid of 18W of heat over a lengthy period (6 hours, with a duty cycle of 92%) if there's no additional switch.With short circuit the built in short circuit protect takes over.
Yes, with adequate heat-sinking.Do you think it can handle 10 watts?
No, they won't start into a short.
Hmmm. I guess I thought that was how we got here.
What are the possibilities?:
The coil just shorted.
The FET just shorted.
The pump stalled and the FET couldn't take it.
I'll take your word for that, but LTSpice says otherwise for the LT1084. However, I was forgetting the Hall device in the pump; that needs a few volts before it will turn on the pump FETs. I've re-run a sim with the pump modelled as the coil in series with an NFET, and the Hall device modelled as a 3V3 zener feeding the FET gate. Better model? Grounding the ADJ pin then cuts off the (non-shorted) pump and 1084 current without having to use another FET. With the ADJ pin high the 1084 output switches high and low at ~ 130Hz, so that would enable rotor lock to be recognised and steps taken to ground the ADJ pin. Not sure if the pump would like being pulsed at 130Hz, albeit with current limited to 6A. The concensus in posts above was that pulsing it (PWM) might be detrimental. Both coil and internal FET dissipate many Watts during the pulsing.No, they won't start into a short.
Chicken and egg comes to mind. We know the coil and external FET fried but can't prove whether the pump internal FET was ok or not.What are the possibilities?: The coil just shorted. The FET just shorted. The pump stalled and the FET couldn't take it.
ronv said:What are the possibilities?:
So don't be in a hurry to build it, Joe! QUOTE]
Ok, alright! Thanks everyboby.
Now we are getting on the same wave length. It's still a litttle marginal. I'm thinking maybe the heatsink is ~30C per watt so at 6 amps it is still going towards 160 C. But at 9 amps we're looking at 330 C at least. Thats solder blob teritory.I'll take your word for that, but LTSpice says otherwise for the LT1084.
I think the pump uses a P Fet. I haven't tried that, but I'll give it a shot. I once tried to build a motor model but all I did was pull my hair out.
I used a lower voltage than 24 so the 1084 would start. That may be the difference. Where I ended up was with a 1/2 ohm in series with the regulator and running it at 20 volt input voltage. The thought being that maybe the FET has a 20 volt gate to source maximum so maybe we should stay under it. It's probably a 30 volt FET so maybe not required.Grounding the ADJ pin then cuts off the (non-shorted) pump and 1084 current without having to use another FET. With the ADJ pin high the 1084 output switches high and low at ~ 130Hz, so that would enable rotor lock to be recognised and steps taken to ground the ADJ pin. Not sure if the pump would like being pulsed at 130Hz, albeit with current limited to 6A. The concensus in posts above was that pulsing it (PWM) might be detrimental. Both coil and internal FET dissipate many Watts during the pulsing.
I haven't been able to duplicate the 130 HZ oscillation with a short. It does oscillate at a low voltage if you make the inductor 0 ohms but a short seems ok. The regulator will get hot but its protection circuity should protect it. ~ 15 watts.
Here is the sim I used.
We would still need something like you had in one post to shut everthing down after a couple of seconds
