Yeah, the 0.22 is like a sausage. I'll try adding a 1.8K parallel to the 4.7K. That would be 2.9K, right?
Yes, the pump did start with 6 amps way back when.
No. Use the 1.8k (or 2.2k) instead of the 4.7k.I'll try adding a 1.8K parallel to the 4.7K.
Adding that resistor across Q1 base-emitter is the riskiest of the fixes. It's the only one which affects the current limit. But certainly add D9/R13 anyway.Could you guys give an opinion on which of the three proposed fixes (D9-R13, snubber, resistor across Q1 base-emitter) Would be the least likely to cook the pumps?
If you're toggling the PDM control voltage (+Vt) you also need to toggle D9 cathode at the same time for the D9/R13 mod to have any effect. It's not going to make a reluctant pump start, but is to allow repeated toggling of a willing pump.D9 cathode is connected to 12V
D2 doesn't need to be a Schottky type, so it may be cheaper to use a standard 8A power diode such as a BYC8D-600:except for the 7.5A schottky.
Useful to have those measurements.Should I check V from Q1 emitter - FET and pump V as before?
Agreed. The ~7-8A current should persist for only tens of millisecs. Thereafter it won't be more than ~3A. Either the pump will run properly, dropping the current down to ~1A after ~ 1sec, or else if the pump stalls the trip should switch it off after ~ 1 sec if the average current is ~3A at that time. So the worst case should be ~ 3A average for ~ 1 sec. Shouldn't get more than warm.Is it agreed that a heatsink won’t be necessary?
I'm guessing the pump rotor started to turn sluggishly, then the Hall switch commutator shut off the coil current before half a rev, the rotor was pulled back magnetically to its starting point and this sequence was repeated. That could have caused the vibration you detected and kept the average current down to ~ 1A.BTW, while I was testing the pumps the alarm did not sound when the motor stalled.
Good catch. I don't think it will be a problem in practice if Joe has the timer set for 5 sec on 5 sec off for testing the Mk13. Just means a 15 sec (?) wait from power-up before we can be sure a pump is/isn't going to run. We could probably design round it by modifying the timer circuit to delay +Vt rise after power-up, but I don't think that's really justified at this point. In practice the 24V power supply may power up slowly anyway, so that too could prevent a high current pulse in the first cycle.The only thing I noticed with the new circuit - and I don't know if it happens- is that on initial power on if the timer is on there is no high current pulse because C4 is not charged up. It recovers on the next cycle, but may confuse debug.
That's a shame; but at least you should have graduated at soldering academy by nowI tried to modify the existing PDM, but was having such an awful time I decided to start fresh.
That's the recommended procedure.This time, I'll build just one in case it needs tweaked.
