Well at least you'll have a couple of spares to hand (hopefully not needed)I think I'll use all new PDMs
That's why I suggested Joe check the LED. If the PDM is powered up without the pump connected the LED should light. Or your proposed method would also do the trick.the LED that's across the pump, maybe it needs a series diode because of the reverse breakdown spikes? It could already be damaged?
What voltage does your DMM show between Pump+ and Pump- when the pump's running but the LED isn't lit?
Best wishes for the extraction etc, KISS.
Sounds like the LED has failed short-circuit. I'd try another LED, with a 1N4148 (or whatever you've got) diode in series with it as Ron suggested. Get well soon!0V across LED for pump on PDM with pump running.
That's fine. It does, however, suggest that a 12V battery for backup of the power supply won't be enough to give you a decent pump speed for non-feed situations. At some point we'll have to re-think the backup system if you go that route.with pump at a low speed I got 11.3V
Well, I think that LED is toast. I disconnected the PDM from speed control and hooked up the tide controller, just to make sure there wasn’t something about speed control the LED did not like. The pump toggled like it’s supposed to, but the LED is dead. When I replace the LED, does it matter which leg of the LED gets the diode? Should the anode or the cathode be connected to the LED?@alec
Not sure what schematic we are talking about, but if it's the LED that's across the pump, maybe it needs a series diode because of the reverse breakdown spikes? It could already be damaged?
@Joe
If you happen to have a 9 V battery and something near a 10K resistor, you can put them in seres to get a 0.9 mA or so current source. Now, connect the combination to the LED and measure with your voltmeter, the voltage across the LED in both directions and report.
My only intention for battery backup is to keep some water moving through the filter to prevent stagnation. Two pumps at that 11.3V speed looked good to me for emergency backup. I would probably not feed at all during that time. So, if we can rig it up to run on low during a power outage, that would buy me time and that would be great.That's fine. It does, however, suggest that a 12V battery for backup of the power supply won't be enough to give you a decent pump speed for non-feed situations. At some point we'll have to re-think the backup system if you go that route.
Salty Joe said:When I replace the LED, does it matter which leg of the LED gets the diode? Should the anode or the cathode be connected to the LED?
In that case a 12V battery backup will be ok. That simplifies things.My only intention for battery backup is to keep some water moving through the filter to prevent stagnation. Two pumps at that 11.3V speed looked good to me for emergency backup.
Fraid not. The leg next to the flat on the LED body is the LED cathode (-ve leg). Connect that to the diode anode. Or connect the LED anode to the diode cathode.Not sure I have this right
That should be so, though it might be better to run the pump at 12V to move it's operating point a bit above the limit of not working. It won't make much difference to the battery discharge rate.I thought the lower the voltage the pump was running on, the longer the battery would last.
