()blivion
Active Member
Well if we assume for convenience the pump max rpm is 1800, then for a 2-pole 2-phase motor that's 60 pulses per sec. Agreed, switching more often than before; but still s-l-o-w by most FET-switching standards (e.g. conventional PWM) and doable without having to use high-current drivers for the FET gates (I hope!).
True, I never actually tried to do the math on switching frequency, was thinking in my head PWM speeds for some reason. So then... were you worrying more about instantaneous gate charge current? A quick look says that 4000 series logic IC's can source/sink about 3mA constantly, but instantaneous current is much much higher, about 50mA pulsed. I have no idea for what duty cycle though, could be on for ages.
Bah... whichever, the buffer IC is not to much work to add and is certainly going to be stronger. If it were me, I would tie some buffers together and do a few logic gates per FET. Even if we are not talking about >1Mhz operation, flipping our FET's through the linear as fast as possible is the most energy efficient way to go... Actually.... with your speed controller... aren't we basically doing zero crossing switching? Or at least something close? Or is it more like SCR's?
Attached are the models requested.
Thanks, now I can play with the circuit too
But first.... SLEEP.
