Styx said:do you know what type of machine is used?
is it a direct-on-line machine or does it have electronics with it?
Don't say that!johnl69 said:I know how to make an inverter but controlling the frequency is beyond my scope of knowledge.
Hero999 said:Don't say that!
The inverter I'm talking about doesn't convert 12V to 230VAC but 325VDC to 230VAC. It's just an oscillator with an h-bridge on the output and no transformer.
johnl69 said:Im trying to slowdown the speed of an aquarium pump to make a wavw system,
They are 240vAC, I connected one to a light dimmer switch just to run some test when i turned the switch the voltage dropped and the pumped stopped so i think the only way i can do this is to adjust the frequency, I would like to be able to control the frequency with a PIC if it possible
Yes, an oscillator would give a fixed frequency.johnl69 said:I think i may not have explained myself properly I need to raise and lower the speed of the motor every minute or so, wouldn't an oscillator and h-bridge give a fixed frquency?
Hero999 said:Yes, an oscillator would give a fixed frequency.
Styx said:you wount get 240Vac out due to volt drops, modulation depth.... so keep that in mind
Of course you can get variable frequency oscillators but he wanted to vary the frequency at set time periods which is possible using a VCO and another oscillator but it's probably more convenient to use a PIC.Nigel Goodwin said:???????????????????????????????
Why?, a variable frequency oscillator is an EXTREMELY simple device, certainly no need to use a micro-controller (apart from it's usually a good idea!).
